How much free space needs BigSur have after installation and continuous usage for the operating system/apps to have optimum loading time?
Nikos365
Levovo V-110
intel i3 60060U
intel Graphics 520
10.14.x
How much free space needs BigSur SSD must have after installation for continuous usage and for the operating system/apps to have a fast loading time?
I mean 512GB SSD would make any difference compared to a 128GB SSD?
Depends.
Depends on your needs and what you use the system for.
I have a 200MB partition for BS with 87GB free:
The used space depends on your User data and what applications you have. Example:
I don't have issues with 87GB free space. But once it starts filling up, you will notice the degradation and also receive warnings from macOS.
The speed question is very subjective since it depends on type of SSD, what type of Bus it's on, etc so no-one will be able to answer that for you but yourself on your system.
With Fresh install The system is late to respond
Depends.
I use sublime most of the time to save my scripts or sometimes to open pictures or quitting apps. The global task menu take time to respond Like FILE->OPEN or FILE-SAVE US
Why is that?What is the reason? I have more than 50GB storage free
Sorry I do not understand what that means.
Are you saying that after a fresh install, your system is generally slow to respond to mouse clicks, etc ?
Post your PR files (see last FAQ here)
literally """
The global task menu takes time to respond Like FILE->OPEN or FILE-SAVE US
Why is that? What is the reason? I have more than 50GB storage free"""
I meant the drop-down menu takes time to show options like save, save us quit... etc when click file on the taskbar
literally """
I meant the drop-down menu takes time to show options like save, save us quit... etc when click file on the text editor
It actually depends how much data is being saved to the target disk. Moreover a few general thing which can affect the performance are
- CPU speed (thermal throttling)
- SSD (Different brand offers different speeds). You haven't indicated either you're using a SATA, M.2 or NVMe.
- Bad memory can cause slow in performance
Now, coming to the OS side, a bad configuration (for example, if PM isn't working) lags and delays are normal in such case.
Please check the files EFI. What Mac version requires less CPU power? I mean Which is among "Mohave","BigSur",Vetura" or Monterey. please check the files..Im having an
intel i3 60060U with 12GB of RAM
You have not provided your OpenCore EFI. Without it, it is not possible to see what/how you have configured your laptop.
raymondleung416
