If you see, there is no option to delete the volume. Try to format the Untitled Volume as APFS. Quit Disk Utility, open it again and provide a screenshot.
As far as I know (by googling), I can't actually resize my macOS partition because it's the "last" of the disk.
Click on Cancel and then select container disk5 and click on Partition and provide a screenshot.
Quit Terminal and execute the following commands in Terminal.
Bash:
#Identify the physical disk
sudo diskutil list
#Repair the physical disk partition
sudo diskutil repairDisk disk0
#Resize the physical disk container volume
sudo diskutil apfs resizeContainer disk0s4 0
Post the output of the Terminal
#Identify the physical disk sudo diskutil list
/dev/disk0 (internal, physical): #: TYPE NAME SIZE IDENTIFIER 0: GUID_partition_scheme *250.1 GB disk0 1: Apple_APFS ⁨Container disk5⁩ 137.3 GB disk0s1 2: EFI ⁨MACEFI⁩ 274.7 MB disk0s3 3: Apple_APFS ⁨Container disk1⁩ 112.5 GB disk0s4 /dev/disk1 (synthesized): #: TYPE NAME SIZE IDENTIFIER 0: APFS Container Scheme - +112.5 GB disk1 Physical Store disk0s4 1: APFS Volume ⁨macOS - Data⁩ 80.3 GB disk1s1 2: APFS Volume ⁨Preboot⁩ 362.4 MB disk1s2 3: APFS Volume ⁨Recovery⁩ 623.1 MB disk1s3 4: APFS Volume ⁨VM⁩ 1.1 MB disk1s4 5: APFS Volume ⁨macOS⁩ 15.3 GB disk1s5 6: APFS Snapshot ⁨com.apple.os.update-...⁩ 15.3 GB disk1s5s1 /dev/disk2 (internal, physical): #: TYPE NAME SIZE IDENTIFIER 0: GUID_partition_scheme *1.0 TB disk2 1: Windows Recovery ⁨⁩ 523.2 MB disk2s1 2: EFI ⁨NO NAME⁩ 104.9 MB disk2s2 3: Microsoft Reserved ⁨⁩ 16.8 MB disk2s3 4: Microsoft Basic Data ⁨⁩ 998.9 GB disk2s4 5: Windows Recovery ⁨⁩ 662.7 MB disk2s5 /dev/disk3 (internal, physical): #: TYPE NAME SIZE IDENTIFIER 0: FDisk_partition_scheme *250.1 GB disk3 1: Windows_NTFS ⁨w10lib⁩ 250.1 GB disk3s1 /dev/disk4 (external, physical): #: TYPE NAME SIZE IDENTIFIER 0: GUID_partition_scheme *62.0 GB disk4 1: EFI ⁨EFI⁩ 209.7 MB disk4s1 2: Apple_HFS ⁨Install macOS Big Sur⁩ 61.7 GB disk4s2 /dev/disk5 (synthesized): #: TYPE NAME SIZE IDENTIFIER 0: APFS Container Scheme - +137.3 GB disk5 Physical Store disk0s1 1: APFS Volume ⁨Untitled⁩ 757.8 KB disk5s1
#Repair the physical disk partition sudo diskutil repairDisk disk0
Repairing the partition map might erase disk0s1, proceed? (y/N) y Started partition map repair on disk0 Checking prerequisites Checking the partition list Adjusting partition map to fit whole disk as required Checking for an EFI system partition Checking all HFS data partition loader spaces Checking booter partitions Reviewing boot support loaders Checking Core Storage Physical Volume partitions The partition map appears to be OK Finished partition map repair on disk0
Bash:
Started APFS operation Error: -69743: The new size must be different than the existing size
Execute the following
sudo diskutil apfs resizeContainer disk0s1 0
Started APFS operation Error: -69519: The target disk is too small for this operation, or a gap is required in your partition map which is missing or too small, which is often caused by an attempt to grow a partition beyond the beginning of another partition or beyond the end of partition map usable space
sudo diskutil apfs deletecontainer disk0s1
sudo diskutil erasevolume free none disk0s1
Started APFS operation on disk5 Deleting APFS Container with all of its APFS Volumes Unmounting Volumes Unmounting Volume "Untitled" on disk5s1 Deleting Volumes Deleting Container Wiping former APFS disks Switching content types 1 new disk created or changed due to APFS operation Disk from APFS operation: disk0s1 Finished APFS operation on disk5 Removing disk0s1 from partition map
Unable to find disk for disk0s1
Provide the output of the following
sudo diskutil list
mohthearrow
