Which USBInjectAll recommend Sir? I found 3 files:
As your system is not latest, anyone should be good. Either use first or third one.
Reactions: oldman20
Thank for your great help!
My board Z790 has 4 usb c all 4 charge my ipad when connected but only 1 allows it to show up in finder. Did I map my ports incorrectly? I'm going crazy trying to determine why sleep is broke :)
Mapping looks correct if you have all the ports working. Make sure XchiPortLimit Quirk is disabled and no USBInjectAll.
I used Hackintosh to mapping USB, as far as I know HSxx is USB2.0 and SSxx is USB3.0, but my port typeC show XHC3 - SSP1
Should I set connector type ? typeC+Sw right ?
Looks good!
However, the BT must be set as Internal.
@EliteMacx86
Hi there...
I know that changing bluetooth connector type to 255 is a must.
But what about internal webcam and sdcard reader, should it also be set to 255 if both connected to internal USB?
That is coming from your Thunderbolt Card/built-in Chip. Just exclude them as the SSDT takes care of it.
mohthearrow
