desktop intel hd4400 7mb
And then, for example, if I use dvi, surely the Intel hd4400 will be fine with these settings? And a vga-hdmi converter is good for this?
VGA to HDMI connector may not work. Although, DVI to HDMI should work.
And there is no way to make it work with vga?
VGA to DisplayPort may work. Unsure about VGA to HDMI.
I can confirm that DVI to HDMI works.
You can try to patch connectors. Assuming, the physical connector is 0x06 and the index is 2, add the following to the IGPU address in DeviceProperties
framebuffer-con1-alldata = 02020A00 0100000 87000000
framebuffer-con1-enable = 01000000
For more info on connectors patching, refer to the thread linked below.
Vga patching is not possible?
Even with these framebuffers, the boot stops here: ioconsoleusers gioscreenlockstate 3.
Then, use the Adapter. DVI to HDMI or VGA to DP/HDMI. Of course, remove the patch which was mentioned in post #14.
bobawoz
