SOLVED Instant wake after sleep with black screen
crypolarbear
MSI Z590i Unify
10700k
Rx 6800xt
Hi everyone! I am new to the hackintosh community and this is my first post here. Recently, I tried to build a hackintosh with the msi z590i unify mothorboard, and one with the msi z590 ace, which is pretty similar to the z590i unify build. The one with z590 ace works pretty good with some minor issues, but the sleep/wake works fine. Although the efi config of the z590i unify one is basically edited from the z590 ace build, the sleep function seems to be broken for some reasons on it.
Here is the hardware:
Motherboard: MSI Z590i Unify
CPU: 10700k
Graphics: Rx 5300
Wifi & BT: Onboard Ax210
OS X: macOS Monterey 12.6
Bootloader: OpenCore
Mac: iMac20,2
It wakes immediately after going into sleep. And it just goes into a loop of continuously sleep and wake with black screen until I use the keyboard or mouse to wake it. I've tried to disconnect all usb devices and ethernet, and it still failed. The onboard ax210 wifi&BT module was enabled in bios, but I didn't include drivers for it and the usb port of BT wasn't mapped as well. I also tried to disabled it in the bios but the result remained the same. So I don't think it was the cause.
I looked up into the wake reason and found out the RP04 was the only reason, but there was no RP04 in my system. That's just weird.
The usb ports are all properly mapped. And the internal usb2.0 hub connector is set to intenal type as well, even though there is no device connected to it for now. I used the USBToolBox to map them. Both the UTBMap.kext with USBToolBox.kext and the USBMap.kext with Apple native management methods were tested, but the sleep still failed. I also tried using the universal ssdt files provided by the OpenCore guide and then generating my own ssdt files with SSDTTime. Make no difference in both cases.
The pmset seems fine as well.
The igpu is enabled for HW acceleration and set to display mode framebuffer 00009B3E since empty framebuffer for headless mode doesn't work at all. The z590 ace build has the same setting for igpu and the sleep function works fine, so I don't think it's cause.
I really have no idea of what affected the sleep function. Any ideas or help are much appreciated. The z590i unify is such a great option for hackintosh and I really want to make it work as perfect as I can. Spent many days on it. Hoping someone here can help me. Thank you!
Here is the PR files including EFI and ioreg.
Yes, it still wakes up. Here is the output.
Post the BIOS version and build date.
Also, execute the following command and post the output.
pmset -g log | grep "failure"
Are you using any sort of internal USB Device such as a CPU Cooler?
BIOS version: E7D05IMS.150
Build date:04/06/2022
There is no output for this command.
No, I don't have any internal device other than the onboard ax210, which I have disabled in the bios. And the internal usb2.0 hub was mapped and set to internal type as well. My cpu cooler is thermalright frozen magic 360 scenic, which has no usb connection. It's so weird I know. But thanks for your patience! Much appreciated!
Apply the following SSDT-GPRW followed by the GPRW patch.
1. Add the SSDT-GPRW.aml to your config.plist under ACPI>Add section and also place it in EFI/OC/ACPI directory.
2. Add the following GPRW patch to your config.plist under ACPI>Patch section.
Find: 47505257 02
Replace: 58505257 02
Comment: change Method(GPRW,2,N) to XPRW, pair with SSDT-GPRW.aml
Enabled: True
Once you're done with the changes, simply save your config.plist and reboot the system and reset NVRAM twice.
Find: 47505257 02
Enabled: True
Still wakes up. I think I did it right?
I did reset the nvram twice.
I searched for the wake reason and still the same RP04 reason.
Flash 7D05v11 BIOS. Reset BIOS Defaults, setup BIOS again, and Save and Exit Changes. Reset NVRAM twice, provide the new bootlog and test Sleep/Wake.
Sorry for the late reply! The MSI BIOS download page gave no response when I went to the page, so I had to gave up. However, I compared the efi with the one that I modified from a github share: z590i unify efi , which I have tried the sleep worked fine with it before. I made a few changes in reference with that efi and the sleep function works perfectly now.
Modification:
AAPL,ig-platform-id: 00009B3E -> 07009B3E
ApplePanic: enable
DisableWatchDog: enable
Driver: HfsPlus.efi -> OpenHfsPlus.efi
This is the current EFI of my build. Everything works pretty good. Just a few minor issues. It will be much appreciated if you can help me with the rest. Thanks again for your help and your patience! I think my build is nearly perfect now! It would be great to solve the rest! Thank you!
Working:
2.5g eth
Onboard audio (rear & front output with DP & HDMI)
iGPU acceleration (sometimes hevc unable shown in videoproc, but actually working, reboot may solve)
TB4 (SSDT injected, correct pcie device path shown in ioreg. Not tested with TB device yet, but should be fine)
Sleep (no error spotted yet under different scenarios)
Usb map (rear panel, all mapped but TB ports usb2.0 disabled. Front panel, one type c switch 3.0 & 2.0, one type A 3.0 & 2.0. Internal USB2.0 Hub mapped and set to Internal type for BT module that I'm going to install. If someone'd like to replace the onboard ax210, remapping the usb port used by the wifi slot is required)
Not working:
Wifi & BT related functions (waiting for my native apple wifi card BCM943602CS to install, but there should be no configuration required)
IGPU display unsupported due to 500 series mb
IGPU headless mode unsupported, must set to non empty frame buffer to enable hardware acceleration
Black screen for a minute before booting into the login page with amd rx6000 series dGPU. Few seconds only with rx 5300.
No dGPU HDMI audio
I'm not planning to use the iGPU as display output, so I'm just hoping to get the dGPU display and audio output work with both DP & HDMI connection.
This setting can also enable iGPU hardware acceleration, so it seems to have no effects on the use of the hackintosh. Just curious whether there is any potential effect on the system with this setting.
I’ve not seen anyone reporting this problem, so I have no idea where to get started. It has very little effect on the use of the hackintosh, but the long time waiting On each boot is still annoying. Hoping to get it fixed.
No dGPU HDMI audio
I’ve seen posts about the similar problem with iGPU only system and guides of patching the iGPU HDMI audio, but there is no post about the issue with dGPU. As this could affect the use of the hackintosh, fixing it will be my main objective.
Hoping this is not too much for one post! Or should I create a new post regarding these issues? Thank you!
Here is the PR you may need for my current hackintosh setup. Thank you!
That's weird. It could be your cache and cookies or an issue from their end too.
Modification:
ApplePanic: enable
I noticed them but didn't pay much attention as the log was not indicating anything about it.
Anytime!
Any specific reason you're using IGPU? RX 6800XT already supports HEVC.
Implementation seems fine and should work normally.
On some systems, running Monterey and later, BT function is affected. See Fixing Bluetooth on macOS Monterey and later for more information.
Comet Lake IGPU is supported, regardless of the Motherboard series. Either 400 or 500 series.
Are you using DP or HDMI?
No dGPU HDMI audio
That's weird.
natsukiro
