SOLVED Instant wake after sleep with black screen
crypolarbear
MSI Z590i Unify
10700k
Rx 6800xt
Hi everyone! I am new to the hackintosh community and this is my first post here. Recently, I tried to build a hackintosh with the msi z590i unify mothorboard, and one with the msi z590 ace, which is pretty similar to the z590i unify build. The one with z590 ace works pretty good with some minor issues, but the sleep/wake works fine. Although the efi config of the z590i unify one is basically edited from the z590 ace build, the sleep function seems to be broken for some reasons on it.
Here is the hardware:
Motherboard: MSI Z590i Unify
CPU: 10700k
Graphics: Rx 5300
Wifi & BT: Onboard Ax210
OS X: macOS Monterey 12.6
Bootloader: OpenCore
Mac: iMac20,2
It wakes immediately after going into sleep. And it just goes into a loop of continuously sleep and wake with black screen until I use the keyboard or mouse to wake it. I've tried to disconnect all usb devices and ethernet, and it still failed. The onboard ax210 wifi&BT module was enabled in bios, but I didn't include drivers for it and the usb port of BT wasn't mapped as well. I also tried to disabled it in the bios but the result remained the same. So I don't think it was the cause.
I looked up into the wake reason and found out the RP04 was the only reason, but there was no RP04 in my system. That's just weird.
The usb ports are all properly mapped. And the internal usb2.0 hub connector is set to intenal type as well, even though there is no device connected to it for now. I used the USBToolBox to map them. Both the UTBMap.kext with USBToolBox.kext and the USBMap.kext with Apple native management methods were tested, but the sleep still failed. I also tried using the universal ssdt files provided by the OpenCore guide and then generating my own ssdt files with SSDTTime. Make no difference in both cases.
The pmset seems fine as well.
The igpu is enabled for HW acceleration and set to display mode framebuffer 00009B3E since empty framebuffer for headless mode doesn't work at all. The z590 ace build has the same setting for igpu and the sleep function works fine, so I don't think it's cause.
I really have no idea of what affected the sleep function. Any ideas or help are much appreciated. The z590i unify is such a great option for hackintosh and I really want to make it work as perfect as I can. Spent many days on it. Hoping someone here can help me. Thank you!
Here is the PR files including EFI and ioreg.
CPU: 10700k
Graphics: Rx 5300
Mac: iMac20,2
Incomplete PR files attached.
- IOReg is corrupt. Use v2.1
- Hackintool>PCIe Export is missing
- Kextcache output is missing
I see, here it is. Thank you!
Provide the following:
- Bootlog. Execute the following command in Terminal.
log show --last boot | head -1500 > ~/Documents/bootlog.txt
- Tableset. Using MaciASL>File>Export Tableset.
Ok, here it is. But I just shutdown and reboot it. Hope it is still valid.
Your bootlog contains one Table load failure.
2022-10-20 08:09:57.409380+0800 0x75       Default     0x0                  0      0    kernel: (AppleACPIPlatform) ACPI Exception: AE_NOT_FOUND,
2022-10-20 08:09:57.409382+0800 0x75       Default     0x0                  0      0    kernel: (AppleACPIPlatform) (SSDT:xh_rksu4) while loading table
2022-10-20 08:09:57.409383+0800 0x75       Default     0x0                  0      0    kernel: (AppleACPIPlatform) (SSDT:xh_rksu4) while loading table
2022-10-20 08:09:57.409384+0800 0x75       Default     0x0                  0      0    kernel: (AppleACPIPlatform)  (20160930/tbxfload-319)
2022-10-20 08:09:57.409385+0800 0x75       Default     0x0                  0      0    kernel: (AppleACPIPlatform)  (20160930/tbxfload-319)
2022-10-20 08:09:57.412118+0800 0x75       Default     0x0                  0      0    kernel: (AppleACPIPlatform) ACPI Error:
2022-10-20 08:09:57.412119+0800 0x75       Default     0x0                  0      0    kernel: (AppleACPIPlatform) ACPI Error:
2022-10-20 08:09:57.412120+0800 0x75       Default     0x0                  0      0    kernel: (AppleACPIPlatform) 1 table load failures, 19 successful
2022-10-20 08:09:57.412122+0800 0x75       Default     0x0                  0      0    kernel: (AppleACPIPlatform)  (20160930/tbxfload-342)
You can simply drop the Table causing the issue. To drop the Table, create a new entry in your config.plist under ACPI>Delete section with the following data
  • TableSignature: SSDT
  • OemTableId: 78685F72 6B737534
  • Table Length: 0
  • Comment: Drop xh_rksu4
  • Enabled: True
Once you're done with the changes, simply save your config.plist and reboot the system and reset NVRAM twice. Delete the old bootlog and generate a new one.
  • Table Length: 0
  • Enabled: True
I'm sorry, but I don't know how to drop this table. I couldn't find it in my config.plist. Is there any other tool that I need to locate it? Or can you give me detailed instruction of how? Please forgive my silly question, I'm still new to hackintosh.
To drop the Table, create a new entry in your config.plist under ACPI>Delete section. Read Post #6
Oh, how fool I am! Thank you for explanation! Here is the new bootlog.
Oh, how fool I am!
Happens 😁😁
The error seems to be fixed.
2022-10-20 09:11:45.410118+0800 0x75       Default     0x0                  0      0    kernel: (AppleACPIPlatform) ACPI:
2022-10-20 09:11:45.410120+0800 0x75       Default     0x0                  0      0    kernel: (AppleACPIPlatform) 19 ACPI AML tables successfully acquired and loaded
Try to put the system into sleep mode. If it wakes up, execute the following command and post the output.
pmset -g log | grep -e "Sleep.*due to" -e "Wake.*due to"
hhhhmnjh
