Gigabyte Z590 Vision D - i9 11900K - Asus Radeon RX 6600 XT with EFI
Olecko
Core i9 11900K
Gigabyte RX 7900 XTX
Hello. I am new on this forum, but not in this hackworld ))
UPD.
After a few days of playing in mac hacker, I was able to run macOS on my setup.
So, I have SMBIOS iMacPro1,1 with this hardware:
O.C. - 0.8.5 - macOS Monterey 12.6 (21G115)
CPU - OctalCore Intel Core i9-11900K, 5100 MHz (51 x 100) - Works with cpu spoof
Cooler - Corsair iCUE H115i ELITE CAPELLIX - Works
MoBo - Gigabyte Z590 Vision D - Works
Audio - Realtek USB Audio ® ALC4080 codec - Works without any Apple ALC
RAM - Corsair VENGEANCE® RGB PRO 32GB (2 x 16GB) DDR4 DRAM 3600MHz C18
USB - Tiger Lake-H USB 3.2 Gen 2x1 xHCI - Works with USBmap kext
GPU - ASUS AMD Radeon RX 6600 XT Dual OC - Works with boot arg "agdpmod=pikera"
SSD - KC3000 PCIe 4.0 NVMe M.2 1TB - macOS Monterey
SSD - Samsung 970 EVO 1TB - Windows 11
SSD - WD SN750 1TB - macOS Data
Network - Intel I225-V Ethernet Controller x 2 Work with boot arg "e1000=0" + DeviceProperties
WIFI + BT - Intel Wi-Fi 6 AX200 160MHz Will be replaced soon, any suggestions?
Monitor - Xiaomi Mi Monitor XMI3444 3440x1440 144GHz Works via DP
I am planning to install macOS Monterey on my new built:
Core i9 11900K
Asus RX 6600 XT Dual OC
2x16Gb Corsair Vengeance 3600MHz
SSD's:
Kingston KC3000 for macOS Monterey
Samsung 970 EVO for Windows 11
WD SN750 for macOS data
Your hardware is compatible. The least you would require is Monterey 12.4.
I found some EFI folders for my motherboard on the internet and tried to boot the installed Monterey on Samsung SSD.
Not the best idea. Instead, you should create your own configuration for your specific hardware.
I know about the TRIM issue.
Yes, either disable TRIM or replace the SSD with a compatible one.
Hello. I started from 0 with the latest opencore.
I was able to install macOS Monterey 12.6 with iMacPro1,1 SMBIOS.
But I can not check or setup all my hardware :(
After I provide the password I have an instant reboot. And I am in the loop with it.
Here is my EFI folder.
I really need help .
BTW, I can not reset NVRAM. "AllowNvramReset" and "ToogleSIPenable" don't work anymore. I am on OC 0.8.5.
Update. Seems I found my problem. I think it was a bad boot arg. for ethernet, I used dk.e1000=0 but now it is e1000=0.
Now I need to configure Thunderbolt in my mobo.
No EFI folder attached.
How do populate the NVRAM reset and SIP enable buttons in OC 0.8.5?
Geekbench score
Metal score
Open CL
Screenshot 2022-10-17 at 00.20.16.png Screenshot 2022-10-17 at 00.23.06.png Screenshot 2022-10-17 at 00.24.28.png
"STEP 3: Enable the AllowNvramReset option in the Misc>Security section of your config.plist"
Does not work in OC 0.8.5
Absolutely. Read Step #4.
dodikhokh
