Intel Gigabyte Z490 Vision D
lightpower
Gigabyte Z490 Vision D (Bios ver. F6)
i9-10850K
IGPU-UHD630
10.13.x
  1. Other
Hello to all friends!
I said to make and share this thread as I run my hack in the following system 100% operation. In order for anyone who has an appetite for more improvement in this system to gather the material in this thread.
My system is as follows:
Imac 20,2
BigSur 11.1 (20C69)
OpenCore 0.6.5
Motherboard:
Cpu: i9-10850k
Gpu: IGPU (UHD-630)
Ram: 64GB Corsair 3200Mhz
Wifi / Bluetooth: Onboard
Working​
  • Tested with macOS Big Sur
  • Wifi and Bluetooth
  • Audio: Realtek ALC1220-VB (AppleALC.kext, alcid=1, FakeID.kext, FakePCIID_Intel_HDMI_Audio.kext)​
  • USB, all ports work​
  • Thunderbolt 3 no tested​
  • 1Gbit Ethernet (Intel I219-V)
  • 2.5Gbit Ethernet (Intel I225-V)
  • With iMac20,2: SideCar and AppleTV, Applestore,DRM
  • Sleep/Wake
  • Shutdown
  • Restart
My EFI is available and works maybe 100%
Downloaded without fear
Imac 20,2
BigSur 11.1 (20C69)
OpenCore 0.6.5
Motherboard:
Cpu: i9-10850k
Gpu: IGPU (UHD-630)
Working​
  • Sleep/Wake
  • Shutdown
  • Restart
good afternoon , I am trying your Efi and I can t get it to work
I on new os and looking to make my intel Gpu to work as well
can you help me please
What is not working for you?
I have a similar setup and cannot get thunderbolt hot plug to work. I had it working before. I followed your instructions and thunderbolt works when things are plugged in but no hot plug.
Fill in your profile
Oh right, thank you for pointing that out.
I've attached EFI, i also have all the reccomended settings in the Bios set to what I read are the correct settings
Anyone have any idea what I'm doing wrong?
김영재
