GUIDE How to Disable CFG Lock | Unlock MSR 0xE2 Lock | Unlock CFG Lock
What is CFG Lock?
CFG-Lock is
Should you Disable CFG-Lock?
Removing the CFG Lock enables better compatibility with Mac and better CPU and power management.
CFG Lock prevents OS X from writing to a certain region in your BIOS. OS X does this for power management and other reasons, and if it can't access it, it will not boot.
CFG-Lock on Ivy Bridge and Prior
Ivy Bridge and older Motherboards featuring chipsets such as Z77, do not have a CFG Lock. If you attempt to unlock the CFG Lock on such Motherboards, the firmware doesn't support CFG Lock. You might have a question "If CFG Lock isn't supported on Ivy Bridge and older, how can I boot into macOS without Kernel Panic." Secondly if that's the case, "how have people been able to boot on such Motherboards since the time of OS X." There is an answer to both of your
Available Methods for Unlocking CFG Lock
Following are the methods available for unlocking CFG-Lock. All these methods have been described below.
MethodRemarks
BIOS
  • Easy to unlock
  • Not supported by every Vendor
  • Can only disable CFG-Lock
CFGLock.efi Tool
  • Easy to unlock
  • May not work on every system
  • Can only patch MSR 0xE2 register
  • CFG-Lock will be enabled if you reset your BIOS
  • CFG-Lock will be enabled if you update your BIOS
UEFIPatch Tool
  • Easy to unlock
  • Works on most of the systems
  • May not work where the System requires the same BIOS signature.
  • Certain Motherboards may reject the BIOS with a security violation error when flashing a modded BIOS. SPI Flasher Required in such case.
  • Can patch MSR 0xE2 and 0x1AA registers
  • Supports Sandy Bridge, Ivy Bridge, Sandy Bridge-E, Ivy Bridge-E, Haswell, Haswell-E, Broadwell-E, Skylake, Skylake-X, Kaby Lake, Cascade Lake
  • Supports C422, X299, C620, C621 Chipsets
  • CFG-Lock will remain disabled if you reset your BIOS
Ru.efi Tool
  • Can be difficult to unlock
EFI Shell (Manual)
  • Cannot be used on Laptops and OEM Systems like HP and Lenovo as it often has a locked/encrypted BIOS and the Variables cannot be unlocked.
Recommended Configurations
If MSR 0xE2 is Locked
CPUmacOSKernelXCPM/AppleXcpmExtraMsrsKernelPm/AppleXcpmCfgLockAppleIntelCPUPM/AppleCpuPmCfgLock
Ivy Bridge and older (including Ivy Bridge-E)AnyNO*YES
HaswellOS X 10.10 and olderYESYES
Haswell and newerOS X 10.11 and newerYESNO
If MSR 0xE2 register is Unlocked or doesn't exist
AnyAnyNONO
i wonder Disable CFG Lock can harmful for others OS? Like windows, linux?
Reactions: oldman20
Reactions: oldman20
I have been done Unlock :)
Is it normal to be stuck at the "Brumbaers CFG Unlock"? Yes, i know that this post could be outdated, but i just need it to work
P.S i restarted, and ControlESRE2.efi says that i have locked CFG-Lock
Then you'll have to unlock it. If you're unable to unlock for any reason, then you can use the quriks.
jkzql77089
