How to Disable CFG Lock | Unlock MSR 0xE2 Lock | Unlock CFG Lock
What is CFG Lock?
CFG-Lock is
Should you Disable CFG-Lock?
Removing the CFG Lock enables better compatibility with Mac and better CPU and power management.
CFG Lock prevents OS X from writing to a certain region in your BIOS. OS X does this for power management and other reasons, and if it can't access it, it will not boot.
CFG-Lock on Ivy Bridge and Prior
Ivy Bridge and older Motherboards featuring chipsets such as Z77, do not have a CFG Lock. If you attempt to unlock the CFG Lock on such Motherboards, the firmware doesn't support CFG Lock. You might have a question "If CFG Lock isn't supported on Ivy Bridge and older, how can I boot into macOS without Kernel Panic." Secondly if that's the case, "how have people been able to boot on such Motherboards since the time of OS X." There is an answer to both of your
Available Methods for Unlocking CFG Lock
Following are the methods available for unlocking CFG-Lock. All these methods have been described below.
Recommended Configurations
If MSR 0xE2 is Locked
If MSR 0xE2 register is Unlocked or doesn't exist
What is CFG Lock?
CFG-Lock is
| Method | Remarks |
| BIOS |
| CFGLock.efi Tool |
| UEFIPatch Tool |
| Ru.efi Tool |
| EFI Shell (Manual) |
| CPU | macOS | KernelXCPM/AppleXcpmExtraMsrs | KernelPm/AppleXcpmCfgLock | AppleIntelCPUPM/AppleCpuPmCfgLock |
| Ivy Bridge and older (including Ivy Bridge-E) | Any | NO* | YES | |
| Haswell | OS X 10.10 and older | YES | YES | |
| Haswell and newer | OS X 10.11 and newer | YES | NO |
| Any | Any | NO | NO |
