GUIDE How to Disable Discrete Graphics in Dual GPU Laptops (NVIDIA/AMD) on macOS
This is not origin. But disassembled. Attach fresh ACPI. Make sure you delete the old ones before grabbing new ACPI set.
Why do you insist it's not? it dumped from F4 Clover, and disassembled with iasl. I just work with DSDT.dsl only
That's done to avoid errors. xD
The SSDT in your case is SSDT-11-SgPch.aml, and DSDT. The SSDT-7-OptTabl is already having the correct OFF Method. Patch it using the guide.
Reactions: oldman20
Could you tell me how you define that? While cant find it with check method OFF?
As i said, i followed guide but stuck at found method to disable, cause it has no exist
And that's why i mentioned which of your SSDT has the INI Method. The SSDT is SSDT-11-SgPch.aml
Reactions: oldman20
thank, finally i did, but my correct is SSDT-6-SgPch. I can manager it both DSDT or SSDT (for Clover and OpenCore)
btw, i edited directly, not from find Method (_INF or _OFF, cause cant find they with these cmd
grep -l Method.*_OFF *.dsl
grep -l Method.*_INI *.dsl
You were supposed to patch the SSDT. No idea without PR files.
fly.gao
