nope, I got Clover GUI not showup when ApfsDriverLoader.efi in that, that reason I put it in root to load manual by hand in EFI Shell, Sir
In that case, i recommend you to reinstall the Clover using the guide linked below
Reactions: oldman20
thank Sir, I will, sure!
I tried but same result, I realized if boot Clover via Opencore, macos partition appeared and booted into mac
Attach the new EFI you created.
No, still old. I tried new config for hd5500 from Clover Crate and same result. Both ApfsDriverLoader and HFSPlus efi MUST OUTSIDE drivers folder will make Clover GUI appear, then load them manual in EFI Shell to see macos partition and boot
If you have created the new config, attach them to check further.
Attach your complete EFI.
here sir
again, i must put both ApfsDriverLoader.efi + HFSPlus.efi in root USB to load manual it via EFI Shell, if they exist in EFI\Clover\Drivers then Clover GUI even doesnt show, just blackscreen
here sir
Provide the original Clover Install EFI which you created couple of days ago.
alvarg82
