The question is why are you trying to use apfs.efi instead of using ApfsDriverLoader.efi which is the recommended method. In short, what problem do you have when using ApfsDriverLoader.efi?
i trying use apfs.efi instead cause ApfsDriverLoader.efi make Clover GUI cant show up, but get same result.
So, you mean when you use ApfsDriverLoader.efi, the Clover GUI doesn't works or the Drives don't appear in Clover menu?
both, Clover GUI doesnt show up, just black screen meaning i cant see any driver or else
Okay, now it's clear to me :)
Provide your EFI to check.
Reactions: oldman20
Reactions: oldman20
I will check and then revert. OpenCore is better than Clover.
yes Sir, thank very much again!
Btw, I finding a thread/Guide about external Microphone for combojack 3.5, but can't find Guide, is that thread exist?
Stick to the topic. Create a separate thread for separate issues.
Clover-5148-oldman20-Themes-Deleted.zip
Please sure, thank Ad very much! This Clover EFI didn't map USB yet, as you known :( But still "boot normal" when put ApfsDriverLoader.efi in root USB then load manual in EFI Shell!
Upon my check, the reason why you don't have working is because you have ApfsDriverLoader.efi in the wrong directory. The recommended directory for drivers is EFI/Clover/Drivers/UEFI (for UEFI Systems). To fix, simply move ApfsDriverLoader.efi and HFSPlus.efi to EFI/Clover/Drivers/UEFI directory.
nope, I got Clover GUI not showup when ApfsDriverLoader.efi in that, that reason I put it in root to load manual by hand in EFI Shell, Sir
J.An
