USBInjectAll.kext is required for ports discovery only.Hi, i followed your #1 post and github, and followed github used USBMap.kext dummy with xhciportlimit fault, not usbinjectall.kext? is it same result?
The mapping seems improper as PR12 and HS01 don't have any device connected so they must be removed.tested with USBMap and Hackintool, seem clean ports, but i can see some ports in hackintool are PR12, HS01 or PR01, PR12 in USBMap like this, different with USBMapInjectorEdit.command, dont know is it normal? If not, what are they with Type -1?
Yes, that's correct.And as in picture, i set cardreader hs06 type 255, is it true?
The tool does show ports but you need to check if it is tied to any port. If not, better to remove it.my device has 1 usb3 port and 2 usb2, i checked they work, could i missing any port from 8-17 showed in discover USB Port?
Have already answered this. See Post #7The last, i checked these ports work, so my OC doesnt need RHUB SSDT?
