SOLVED Slow boot time on my Dell laptop hackintosh
Deleted them, still slow boot time.
Disable BlueToolFixup and AirportItlwm and then check. Also, run FirstAid on your Disk to make sure everything is good.
Also, correct your configuration
Disabling the kexts doesn't do anything. Still slow boot. FirstAid says everything is OK.
I performed another check and found some more info
Remove the following
-AirportItlwm.kext
-HoRNDIS.kext
-IntelBluetoothFirmware.kext
-JMB38X.kext
-JMicronATA.kext
-VoodooRMI.kext
-VoodooI2C.kext
-BlueToolFixup.kext
-BrightnessKeys.kext
-ECEnabler.kext
-FeatureUnlock.kext
-HSSDBlockStorage.kext
-VoodooI2CHID.kext
-VoodooI2CSynaptics.kext
Also, use sorted order for the kext loading. The same applies for Drivers
Disable the following Quirks in Kernel>Quirks section of your config.plist
- ExtendBTFeatureFlags
Enable the following Quirks in Kernel>Quirks section of your config.plist
-CustomSMBIOSGuid
-XhciPortLimit
-AppleCpuPMCfgLock
Remove force loading of kext in Kernel>Force
Remove #INFO (prev-lang:kbd) key in NVRAM>7C436110-AB2A-4BBB-A880-FE41995C9F82
Remove the value of prev-lang:kbd in NVRAM>7C436110-AB2A-4BBB-A880-FE41995C9F82
Set UpdateSMBIOSMode to Custom in Platform Info
Remove the following Drivers
-NvmExpressDxe.efi
-OpenNtfsDxe.efi
-OpenPartitionDxe.efi
-Ps2KeyboardDxe.efi
-ToggleSipEntry.efi
These basic cleaning up have been already discussed in the install guide:
Already removed:
-HoRNDIS.kext
-JMB38X.kext
-JMicronATA.kext
Wouldn't I lose WiFi and bluetooth functionality?:
-AirportItlwm.kext
-BlueToolFixup.kext
It's needed for the touchpad to work:
-VoodooRMI.kext
-VoodooI2C.kext
-VoodooI2CHID.kext
I need the brightness keys. Wouldn't removing this disable that?: BrightnessKeys.kext
Isn't this required for EC to work?: ECEnabler.kext
Probably removing, as it doesn't do anything (sidecar only worked in Big Sur): FeatureUnlock.kext
-AirportItlwm.kext
-BlueToolFixup.kext
Yes, WiFi and BT. But here we're tracing what is causing boot delay. Once we determine the culprit, you can enable it later.
-VoodooRMI.kext
-VoodooI2C.kext
-VoodooI2CHID.kext
For tracing, remove these
Yes, but for tracing you need to remove it
Not really. It provides Battery meter function without patching the ACPI
I see. Is disabling from the config.plist enough?
No need to continue this post, a reinstall solved the problem.
noiguer
