HS80211Family.kext Is Not Compatible With macOS 12 Monterey.
i dont remember, but not from news official, just from topic someone said that
It's still working so you shouldn't have any issues.
Reactions: oldman20
When I start my computer with this specific Kext on macOS Monterey the system gives a kernel error and does not start, for the system to start correctly I had to remove this kext for the system to start, everything works but without wi-fi on macOS Monterey.
Hi may you please share your working EFI. I've been trying to switch to OC for months without any luck.
What macOS version are you trying to install?
Monterey.
But I'm currently on Mojave, so I'm trying to get any latest version that's supported.
Monterey.
You can definitely upgrade to Monterey. The first step would be to prepare OpenCore EFI and you can proceed further.
The last time I tried, I got it to start installing then it would freeze after reboot on the Apple logo.
Create a separate thread and attach your PR files. This thread will be closed as the original problem was solved.
  • Sad
Reactions: romeonje
XChikuX
