HS80211Family.kext Is Not Compatible With macOS 12 Monterey.
ThiagoTx
Dell Inspiron 5458
Intel i5500U
Intel HD Graphics 5500
12.0.x
  1. OpenCore
When I start my computer with this specific Kext on macOS Monterey the system gives a kernel error and does not start, for the system to start correctly I had to remove this kext for the system to start, everything works but without wi-fi on macOS Monterey.
  • HS80211Family.kext.zip
11.0.x
  1. OpenCore
What WiFi model?
Reactions: ThiagoTx
ThiagoTx
Dell Inspiron 5458
Intel i5500U
12.0.x
  1. OpenCore
11.0.x
  1. OpenCore
Technically, it should work. We're still testing it. Check the WiFi patch from here
11.0.x
  1. OpenCore
ThiagoTx
Dell Inspiron 5458
Intel i5500U
12.0.x
  1. OpenCore
ThiagoTx
Dell Inspiron 5458
Intel i5500U
12.0.x
  1. OpenCore
Okay I Will Test! ;)
ThiagoTx
Dell Inspiron 5458
Intel i5500U
12.0.x
  1. OpenCore
Unfortunately It Didn't Work, What I Do?
Trending Threads
andyjusa
