not helped, tried even to disable WiFi/BT in BIOS/UEFI. the same output as in video below.
Probably, your system requires the quirk AvoidRuntimeDefrag Quirk. Have you tried to boot Monterey with this quirk disabled?
it is Monterey for that moment. I will try and report soon
Ok, with only -lilubetaall Monterey booted. will try to update to Ventura and report. Thanks :D
This means the system doesn't require AvoidRuntimeDefrag, so you should be able to upgrade or perform a clean install. Make sure to backup your system first.
Changes
22092022
- Installed MacOS Ventura 13.0
- Updated to OC 0.8.5 and latest kexts like WEG to spoof SkyLake (SKL) to KabyLake (KBL)
- AltStore 1.5.1 and iPadOS 16.0 works
Working
- Full graphics acceleration on Intel HD620 iGPU, including brightness control (F5 and F6)
- Multi-display with DisplayPort OOB, VGA
- Audio, microphone input and headset output (F8 and F9) - Mute button not working
- GigEthernet LAN connection
- Wireless and bluetooth with any compatible card (a DW1560 in my case, no Whitelisting)
left and right USB ports including USB Type-C
- Integrated webcam (OOB)
- CPU power management
- Sleep (Lid, Energy Saver settings, Apple menu, PWR button) & wake (Lid, PWR button)
- Battery management
- Keyboard and touchpad
- Keyboard backlight (F5/F6)
- Touchpad including tap-to-click, scrolling, mouse buttons (can be disable with prt scr key)
Set bios settings as follows:
Advanced tab:
Boot options:
- Fast Boot = Disabled
- Network (PXE) Boot = Disabled
Secure Boot Configuration:
- "Legacy Support Enable and Secure Boot Disable"
System Options:
- Virtualization Technology (VTx) = Disabled (recommended, Enable also worked)
- Virtualization Technology for Direct I/O (VTd) = Disabled (recommended, Enable also worked)
Built-In Device Options:
- Wake On LAN = Disabled
- Video memory size = 64 MB
- LAN/WLAN Auto Switching = Disabled
- Fingerprint Device = Disabled
Power Management Options:
- Extended Idle Power States = Disabled
- Deep sleep = You can keep this enabled
- Wake when Lid is Opened = Enabled
- Wake on USB = Disabled
Credits
OSXLatitude - Herve, Jake Lo
TonyMacx86 - Feartech
EliteMacx86 - @EliteMacx86 for his guidance on Ventura and graphics spoofing
Opencore Dev Team
Check out Working EFI
Changes
22092022
Working
Advanced tab:
Boot options:
System Options:
Credits
Opencore Dev Team
Good Hack!
Change4209
