Common Problems in macOS Ventura (13.0)
This thread is for common problems in macOS Ventura. The problems listed here are likely to be experienced by users who attempt to install macOS Ventura 13.0.
This is not a troubleshooting thread. Please do not ask questions regarding your specific issue in this thread. If you're having an issue, create a separate thread. If you're having a problem to report or have a workaround to resolve the problems listed here, regarding the installation or function in macOS Ventura, you can reply to this thread.
Stuck on [EB|#LOG:EXITBS:START]
macOS Ventura requires the following
On a side note, it would be best to disable WiFi and Bluetooth related kexts and it applies to both, Broadcom and Intel.
A required firmware update could not be installed
If you're installing macOS Ventura, you might have seen this error in the second phase of the installation, where it boots from macOS Installer to continue the installation, but then prompts with A required firmware update could not be installed. This is mostly happening on the systems requiring AvoidRuntimeDefrag Quirk. 300 series Motherboards are mainly affected.
For users having this issue, read here
elitemacx86.com
IGPU Graphics Acceleration
Apple dropped all the IGPU Graphics support up to Skylake. Users with Skylake and prior would not be able to use their IGPU, until there is a development from OCLP team. To install on systems with unsupported IGPU, use
For Skylake Users
elitemacx86.com
NVIDIA Graphics Acceleration
With macOS Monterey, Apple completely removed support for NVIDIA. However, a workaround was to use OCLP, but at the moment, the OCLP is unable to patch the system on macOS Ventura.
No Disk in Disk Utility
Some SATA Controllers are removed in macOS Ventura. The solution is to use CtlnaAHCIPort.kext
No USB Ports
Since macOS Big Sur 11.3, Apple made some changes and the XHCI Port Limit patch was broken. A solution is to map the ports.
elitemacx86.com
Administrator User Name and Password Requirement during macOS Ventura Beta 2 Clean Install
Since macOS Ventura Beta 2, the installer requires a Username and Password during a clean installation. The solution is provided below.
elitemacx86.com
No WiFi and Bluetooth function
On macOS Ventura, the WiFi and Bluetooth may not work. A solution is to update Lilu, VirtualSMC, and the Bluetooth related kexts. In addition, the USB ports must be mapped.
elitemacx86.com
No Ethernet
On macOS Ventura, there is a very likely chance that your Ethernet won't work, including built-in any PCIe based such as AQuantia. To fix this issue, you'll need to enable VT-d on your System. Note that some systems may require memory mapping (fixing DMAR Table).
elitemacx86.com
elitemacx86.com
Cannot Update to macOS Ventura Beta 3
Since macOS Ventura Beta 3, OC v 0.8.2 no longer works and you need to update the OC to v 0.8.3 along with all the necessary kexts. Once upgraded, boot with the new version and proceed with the upgrade. Clover users need to use 5148 release.
- OpenCore v0.8.2 or later
- Updated Kexts
- -lilubetaall bootarg
GUIDE - How to Fix Administrator User Name and Password Requirement during macOS Ventura Clean Install
How to Fix Administrator User Name and Password Requirement during macOS Ventura Clean Install An EliteMacx86 Exclusive Guide - This guide covers fixes Administrator User Name and Password requirement during macOS Ventura Beta 2 Clean install. Overview Apple announced their new macOS lineup...
elitemacx86.com
-igfxvesa in boot arg.For Skylake Users
GUIDE - How to Enable Intel Skylake Graphics (Intel HD Graphics 515, 520, 530, 540, 550 and 580) on macOS Ventura and Later
How to Enable Intel Skylake Graphics (Intel HD Graphics 515, 520, 530, 540, 550 and 580) on macOS Ventura and Later An EliteMacx86 Exclusive Guide - This guide covers fixing Intel Skylake Graphics on Desktops and Laptops for macOS Ventura and Later. By following this guide, you'll be able to...
elitemacx86.com
No USB Ports
GUIDE - How to Map your USB Ports on macOS
How to Map your USB Ports on macOS An EliteMacx86 Exclusive Guide - This guide covers the mapping of USB Ports on macOS. By following this guide, you'll be able to map your USB ports and can also achieve a proper speed for your USB ports. I. Overview Often, the USB ports are not well...
elitemacx86.com
elitemacx86.com
GUIDE - How to Fix Bluetooth on macOS Monterey and Later
How to Fix Bluetooth on macOS Monterey and Later This guide covers fixing Bluetooth on macOS Monterey and Later using Clover and OpenCore. By following this guide, you'll be able to enable Bluetooth on macOS Monterey and Later using Clover or OpenCore Bootloader. Background Recently, we...
elitemacx86.com
No Ethernet
GUIDE - How to Enable Apple VTD on macOS [Clover/OpenCore]
How to Enable Apple VTD on macOS [Clover/OpenCore] An EliteMacx86 Exclusive Guide - This guide covers the implementation of the Apple VTD function on macOS for Desktops and Laptops. By following this guide, you'll be able to enable VT-d on macOS using Clover or OpenCore Bootloader. Overview...
elitemacx86.com
GUIDE - How to Fix DMAR Table on macOS | Memory Mapping
How to Fix DMAR Table on macOS | Memory Mapping Overview On some systems, when you enable VT-d which is required for some major functioning of a few particular devices such as Antelope Audio Interface and other Thunderbolt capable Devices, the system starts acting weird and all of the sudden...
elitemacx86.com
