HS80211Family.kext Is Not Compatible With macOS 12 Monterey.
======================= Dell Inspiron 15 3543 (Option UEFI enable) - Intel Core i3 (5th Gen) 5005U / 2 GHz - 8GB RAM - Intel HD Graphics 5500 - 1366x768 - ALC255 - AR9002WB_1NG wifi combo card [AR9285 + AR3011 (bluetooth)] Replaced - RTL8139/810x/Synaptics-SSD (GPT) - Clover bootloader || =======================
Thank you!
Seems like Half Mini PCIe. Can you provide the picture of the current card?
sure sir!
Consider buying Broadcom BCM94352HMB, Half Mini PCIe. Make sure your BIOS doesn't have any whitelist. This can be only confirmed after you install the card.
Reactions: oldman20
thank, any hope for bluetooth too?
Reactions: oldman20
Reactions: oldman20
can i use it with BCM94360CS2 in my case?
Reactions: oldman20
Should work. But why not buy Broadcom BCM94352HMB, Half Mini PCIe? You don't need an adapter for that Card.
i read somewhere 9432 not native and maybe drop in feature?
ryusuke17
