How to get Battery percentage in macOS Monterey.
You need to use MaciASL to patch the ACPI.
YEAH i know that but they told that u have to first make sure there is no errer my problem is that after compiling everything (to not get errors)one SSDT-3-Cpu0Ist.dsl is still having error so how do i fix that?
Apply the Placeholder patch to remove the error. Looks like you didn't read the guide carefully.
Ohh ok i got it ok so now as the guide says what should i add as my layout id if my original layout id is not present my is 84.
And i have a HP EliteBook 840 g1 which came with windows 8.1 preinstalled so should i select windows 8 or use my current installed windows which is windows 10?
And also should i use Haswell LPC I don't know how to know my current EFI is using AppleALC with alcid=84 and it is working fine ?
You need to change as per yours. xD
If Windows 10 patch gets applied, use Windows 10. If not, use Windows 8 patch.
Depends if the LPC is loading or not.
AppleALC is required. For Layout ID, you need to check as per your Codec.
NO in dsdt patch it only shows 2,3,12,14. But my alcid= 84 so what should i put or should i not do anything?
Change 12 with 84 or any ID you want to use. It's simple ;)
Reactions: Pranay
scoobypetey
