How to get Battery percentage in macOS Monterey.
Pranay
Hp Elitebook 840 G3 motherboard
Intel(R) Core(TM) i5-6300U CPU @ 2.40GHz 2.50 GHz
Intel HD Graphics 520
  2. Clover (Legacy)
  3. OpenCore (UEFI)
  4. OpenCore (Legacy)
  2. iMac Pro
  3. Mac Pro
  4. Mac mini
  5. MacBook
  6. MacBook Air
  7. MacBook Pro
  3. Windows Phone
  4. Other
Hey team EliteMacx86,
I have succesfully installed macOS monterey in My laptop.
But now i want to get my battery percentage so how do i get it please and thankyou.
Regards,
Pranay
Regards,
Pranay
To get Battery Meter, you need to patch your DSDT.
For Battery Specific:
I am getting a error when compiled my 3rd SSDT (Screanshot provided) Screenshot 2022-04-07 at 11.01.04 AM.png
No ACPI files attached.
Or NVM How do I create a Clover EFI to extract ssdt and dsdt as said in the guide cause in that guide it is not told how to create clover EFI for my system.
You don't need to create any particular EFI for extracting the ACPI files. Just install Clover to any target USB and boot using Clover to extract the ACPI files as per the guide.
Incomplete ACPI file attached.
I did not understand?
Do u want .aml file or .dsl?
Apply [syn] Remove _PSS placeholders patch.
How do i do it?
How do i do it?
You need to use MaciASL to patch the ACPI.
mollyshard
