Intel HD 4400 not working on Monterey
Are you using a SATA SSD or M.2/NVMe? Also, if you're booting to installer, how can you determine whether Graphics acceleration is working or not?
I am using SATA SSD. I can determine if my graphics are working as if it is not the resolution will be 1024x768 which is screeched resolution and if it fixed it will go to my native display resolution which is 1600x900
Make sure the SATA Mode is set to AHCI in BIOS. If already, use "CtlnaAHCIPort" kext.
Still, not a proper way to determine acceleration.
LET ME CHECK IN BIOS
IT should be accelerated if its not we can fix that in the future.
Nope no change it still not showing.
EFI👆.Please say if there is any error and I should change anything. Please and thank you
Your configuration is not correct. For the current issue, the CtlnaAHCIPort.kext should be loaded after AppleALC, as your current config.plist. Also, make sure to reset NVRAM twice after the changes. In addition, are you sure if your drive is functional?
So I should put the ctlnaAHCIPort.kext just after AppleALC AND then reset NVRAM twice.
Yes my SSD is functional as i am booting windows through it :)
ryusuke17
