Intel HD 4400 not working on Monterey
Pranay
Hp Elitebook 840 G3 motherboard
Intel(R) Core(TM) i5-6300U CPU @ 2.40GHz 2.50 GHz
Intel HD Graphics 520
  2. Clover (Legacy)
  3. OpenCore (UEFI)
  4. OpenCore (Legacy)
  2. iMac Pro
  3. Mac Pro
  4. Mac mini
  5. MacBook
  6. MacBook Air
  7. MacBook Pro
  3. Windows Phone
  4. Other
Hey team EliteMacx86,
I successfully installed mac os bigsur in my laptop but i want to install xcode which is only supported in mac os montery and above (12.0). So i updated my hackintosh but it did not boot so what i did is created a monterey bootable usb and tried installing but when i booted into the installer the graphics did not work . so if there is a fix for this please help.
regards,
Pranay
regards,
Pranay
The issue is that your Graphics acceleration does not work right?
Then why it's under Apple World?
OHH sry i didn't know i saw MacOS Monterey and clicked on that so should I close this thread and start another in hackintosh?
I'll move the thread. Provide the PR files to check further.
I got to fix the graphics problem by following the steps in the guide present in this website.
So next i booted into installer but now the problem is that my ssd is not showing in the diskutility in this installer .
So if there is a fix please reply the only reason is cause i want Xcode.
EFI👆
EFI👆
Are you using a SATA SSD or M.2/NVMe? Also, if you're booting to installer, how can you determine whether Graphics acceleration is working or not?
rdjosh
