[SOLVED] macOS Catalina and Intel HD 4400
MinecraftW06
Dell Inspiron 15 Series 3000
Intel Core i5 4210U
Intel Graphics 4400
11.0.x
I Installed macOS Catalina, everything is working fine, except the graphics. System Properties shows 4mb, Night Shift and Airplay not working, no brightness slider in System Preferences - Display.
I have Intel HD Graphics 4400.
Can anyone help please?
11.0.x
  1. OpenCore
No PR files attached.
MinecraftW06
Intel Core i5 4210U
Intel Graphics 4400
11.0.x
I attached PR files to this reply.
  • Problem Reporting.zip
11.0.x
  1. OpenCore
Your system has the following issues.
Remove the following kexts from L/E
  • XHCI-unsupported.kext
  • FakeSMC.kext
  • VoodooPS2Controller.kext
  • ATH9KFixup.kext
  • Lilu.kext
  • FakePCIID.kext
  • AppleHDADisabler.kext
  • Niresh'sExtra.kext
  • CPUFriend.kext
  • USBInjectAll.kext
  • NullCPUPowerManagement.kext
  • GenericUSBXHCI.kext
  • FakePCIID_XHCIMux.kext
  • RealtekRTL8111.kext
  • NightShiftUnlocker.kext
  • WhateverGreen.kext
  • FakePCIID_Intel_HDMI_Audio.kext
  • AppleALC.kext
  • VoodooHDA.kext
  • AirportBrcmFixup.kext
  • BT4LEContinuityFixup.kext
  • AHCIPortInjector.kext
  • NoTouchID.kext
  • HibernationFixup.kext
  • ACPIBatteryManager.kext
  • FakePCIID_Intel_HD_Graphics.kext
Remove the following kexts from S/L/E
  • BTFirmwareUploader.kext
The config.plist, drivers and kexts are not as per the guide.
Attach the new PR files.
MinecraftW06
Intel Core i5 4210U
Intel Graphics 4400
11.0.x
I deleted these files, and rebooted. My laptop stuck at IOConsoleUser: gIOScreenLockState 3, hs 0, bs 0, now 0, sm 0x0.
So from an usb, in terminal, I recovered files, and the laptop booted.
11.0.x
  1. OpenCore
Well, if your Laptop was stuck, you could have post the issue. Note that the solution was not to recover those irrelevant kexts. You can follow the instructions or find any other place for help.
MinecraftW06
Intel Core i5 4210U
Intel Graphics 4400
11.0.x
Can you just write the steps, or the problem reporting file is important?
11.0.x
  1. OpenCore
Of course it's mandatory. Refer to this post and attach your new PR files. If you're unable to boot, provide a video of verbose. Also, make sure you follow the Laptop guide to prepare the correct configuration.
MinecraftW06
Intel Core i5 4210U
Intel Graphics 4400
11.0.x
Updated PR files (Also now my computer booted).
  • PR.zip
11.0.x
  1. OpenCore
Remove the following kexts from /L/E
  • ATH9KInjector.kext
  • FakePCIID_BCM57XX_as_BCM57765.kext
  • FakePCIID_Broadcom_WiFi.kext
  • FakePCIID_AR9280_as_AR946x.kext
  • FakePCIID_Intel_GbX.kext
Attach new PR files.
Similar threads
himsic
