HS80211Family.kext Is Not Compatible With macOS 12 Monterey.
Did it worked with previous version of Monterey? Or It didn't worked with any version of Monterey?
It was broken.
ar9285 worked with Big Sur latest! and that's all now :(
any suggest PCIe wifi card can work on Monterey, also Bluetooth!?
Depends on what module will fit in. Provide the details of your system.
======================= Dell Inspiron 15 3543 (Option UEFI enable) - Intel Core i3 (5th Gen) 5005U / 2 GHz - 8GB RAM - Intel HD Graphics 5500 - 1366x768 - ALC255 - AR9002WB_1NG wifi combo card [AR9285 + AR3011 (bluetooth)] Replaced - RTL8139/810x/Synaptics-SSD (GPT) - Clover bootloader || =======================
Thank you!
xxxxxxxxxx
