- Jan 21, 2022
- ASUS TUF GAMING Z490-PLUS (WI-FI) LGA 1200 (Intel 10th Gen) Intel Z490 (WiFi 6) SATA 6Gb/s ATX Intel Motherboard (Dual M.2, 12+2 Power Stages, USB 3.2 Front Panel Type-C, Intel WiFi 6 & 1Gb LAN, Aura Sync)
- Intel Core i3-10100F 10th Generation LGA1200 Desktop Processor 4 Cores 8 Threads up to 4.30GHz 6MB Cache
- Gigabyte GeForce GT 710 2GB DDR3 Memory Graphics Card (GV-N710D3-2GL)
- Other
Hi, I am back again, with another question. Is this specific model compatible with Hackintosh Monterey?
Specs are given below:
Pity I don't have the alc codec. IF COMPATIBLE, plz provide the EFI for it.
Do give me details about the alc codec plz.
For more info, check out this link: https://www.amazon.in/gp/product/B08XNYH4LX/ref=ox_sc_act_title_1?smid=A14CZOWI0VEHLG&th=1
Hope I have given enough info!
Do contact me here if u have any issues
Some other info I found about it:
| Brand | HP | ||
| Model | 34W78PA | ||
| Model Name | HP 15s-fr2006TU | ||
| Model Year | 2021 | ||
| Product Dimensions | 35.9 x 24.2 x 1.8 cm; 1.69 Kilograms | ||
| Batteries | 1 Lithium Polymer batteries required. (included) | ||
| Item model number | 34W78PA | ||
| RAM Size | 8 GB | ||
| Memory Slots Available | 2 | ||
| Flash Memory Installed Size | 512 | ||
| Ram Memory Installed Size | 8 GB | ||
| Maximum Memory Supported | 16 GB | ||
| Ram Memory Technology | DDR4 | ||
| Hard Drive Size | 512 GB | ||
| Hard Drive Interface | Solid State | ||
| Hard Disk Description | Solid State Drive | ||
| Optical Drive Type | No Optical Drive | ||
| Operating System | Windows 10 Home | ||
| Processor Brand | Intel | ||
| Processor Speed | 4.1 GHz | ||
| Processor Type | Core i3 | ||
| Processor Count | 1 | ||
| Processor Model Number | I3-1115G4 | ||
| Graphics Card Description | Integrated | ||
| Graphics RAM Type | VRAM | ||
| Graphics Card Interface | Integrated | ||
| Graphics Coprocessor | Intel® UHD Graphics | ||
| Resolution | 1920 x 1080 | ||
| Special Features | Anti-reflective | ||
| Mounting Hardware | Laptop, Power Adapter | ||
| Number Of Items | 1 | ||
| Software Included | Windows 10 Home | ||
| Standing screen display size | 15.6 Inches | ||
| Display Type | LED | ||
| Resolution | 1920 x 1080 Pixels | ||
| Battery Average Life | 8 Hours | ||
| Batteries Included | Yes | ||
| Batteries Required | Yes | ||
| Battery Cell Composition | Lithium-Ion | ||
| Keyboard Description | Chiclet | ||
| Connector Type | Wi-Fi | ||
| Device interface - primary | Keyboard | ||
| Form Factor | Laptop | ||
| Device Type | Ultrabook | ||
| Manufacturer | hp | ||
| B08XNYH4LX |
- Processor: 11th Gen Intel Core i3-1115G4 (up to 4.1 GHz with Intel Turbo Boost Technology, 6 MB L3 cache, 2 cores)
- Memory: 8 GB DDR4-2666 SDRAM (1 x 8 GB) | Storage: 512 GB PCIe NVMe M.2 SSD
- Display: 15.6-inch FHD IPS anti-glare micro-edge WLED-backlit, 250 nits, 45% NTSC (1920 x 1080)
- Graphics: Intel UHD Graphics
