Gigabyte Z590M (rev.1.0) any support for Monterey 12.X?
smeetgajjar98
Gigabyte Z590M (rev. 1.0)
Intel Core i7-11700K
Intel UHD 750
  1. Mac Pro
Is there any Support for Gigabyte Z590M (rev.1.0)??
I am trying to boot macOS recovery for installing and I got stuck at Loading screen.
My specs:
Gigabyte Z590M (rev.1.0) (check this link for more information https://www.gigabyte.com/Motherboard/Z590M-rev-10 )
Intel UHD 750 (integrated GPU)
1TB SSD Nvme
16GB RAM: 8x2 Corsair 3200Mhz
My specs:
1TB SSD Nvme
The Motherboard is fully supported. Although, the IGPU isn't. You'll need to use a compatible GPU.
Reactions: flopis27
Can anyone help me to build opencore for this particular hardware or any working EFI folder please? Sorry for bad English.
EFI guide is already mentioned here
A guide is already available for your Motherboard
Reactions: flopis27
I searched and found this link too but it is for Gigabyte Z590 Vision G version. Not for Gigabyte Z590M.
Reactions: flopis27
There is not much difference. Use that guide as a reference and you'll have it working.
lucadita
