Help with Hackintool USB map export files??
DASBOOT5
Gigabyte Z370 Aorus Gaming 7
Intel I7 8700K
ASUS ROG STRIX VEGA 64 OC
10.15.x
  2. OpenCore (UEFI)
  2. MacBook Air
  3. MacBook Pro
When Hackintool exports the finalized USB port map kext and files there are 5 file created from the export.
The USBPorts.kext goes in the kext folder this is obvious.
However ; There are two .dsl files SSDT-EC-USBX and SSDT-UIAC what are these files for and where if necessary are the placed? Are these SSDT files?
Finally there are two ACPI files: SSDT-UAIC.aml and SSDT-EC-USBX.aml are these to be placed in the ACPI folder?
Or is only the USBPorts.kext to be used, out of the 5 file export set?
SSDT-EC-USBX is already packaged with OpenCore package so no need to use it from Hackintool.
SSDT-UIAC is meant to be used with USBInjectAll.kext. When using USBPorts.kext, you need to skip it.
So the only pertinent portion of the export after mapping is USBPorts.Kext and correctly configuring the Plist to address this added Kext done preferably with Propertree, using snapshot or clean snapshot then saving.
Exactly!
Write your reply...
kod_mic
