Help with Hackintool USB map export files??
DASBOOT5
Gigabyte Aorus B550i Pro AX
AMD RYZEN 5 1600
SAPPHIRE AMD RX 570 ITX PULSE
11.0.x
  1. OpenCore
When Hackintool exports the finalized USB port map kext and files there are 5 file created from the export.
The USBPorts.kext goes in the kext folder this is obvious.
However ; There are two .dsl files SSDT-EC-USBX and SSDT-UIAC what are these files for and where if necessary are the placed? Are these SSDT files?
Finally there are two ACPI files: SSDT-UAIC.aml and SSDT-EC-USBX.aml are these to be placed in the ACPI folder?
Or is only the USBPorts.kext to be used, out of the 5 file export set?
11.0.x
  1. OpenCore
SSDT-EC-USBX is already packaged with OpenCore package so no need to use it from Hackintool.
SSDT-UIAC is meant to be used with USBInjectAll.kext. When using USBPorts.kext, you need to skip it.
DASBOOT5
AMD RYZEN 5 1600
11.0.x
  1. OpenCore
So the only pertinent portion of the export after mapping is USBPorts.Kext and correctly configuring the Plist to address this added Kext done preferably with Propertree, using snapshot or clean snapshot then saving.
11.0.x
  1. OpenCore
Exactly!
Similar threads
haggar12
