plz help me fix the shutdown isuue on Big Sur 11.6
Nikos365
Levovo V-110
intel i3 60060U
intel Graphics 520
10.14.x
Hello
Every time i try to shutdown my laptop ,it reboots. I need a guide instructions or quickFix
Thanks
Im using Lenovo v-110 15ISK 80TL,12 GB RAM,SSD 128GB,i3 6006U Dual core
I try dortanias OpenCore Guide but it lacks of instructions. Its inadequate...
Hello
Thanks
No PR files attached.
The PR files you have asked
i don't know what PR files should look like. Is there a guide for fix the issue?
PR files are the Problem Reporting Files. It included IOReg, Kextcache Output, EFI, excluding themes or Resources folder.
natsukiro
