GUIDE How to Disable Discrete Graphics in Dual GPU Laptops (NVIDIA/AMD) on macOS
Can anyone help me?
Sadly, that doesn't increase the battery life
Yes, very correct. Provide your original ACPI files to check further.
Sorry for the late reply. Had to put this on hold for a bit.
The files I provided aren't good enough? I got the files trough MaciASL. Unfortunately, I am not able to dump the files with Opencore. I get error after error.
No worries. Use Clover to dump the ACPI files.
Probably, you did NOT followed the guide. First you need to disassemble and then find it in Terminal.
For your ACPI set, you'll find the exact information if you follow the guide.
$ grep -l Method.*_OFF *.dsl
DSDT.dsl
SSDT-11-OptTabl.dsl
SSDT-4-CflH_Rvp.dsl
SSDT-5-Ther_Rvp.dsl
$ grep -l Method.*_INI *.dsl
DSDT.dsl
SSDT-11-OptTabl.dsl
SSDT-3-PegSsdt.dsl
You need to use DSDT.dsl and SSDT-11-OptTabl.dsl to disable the dGPU.
i have same problem, but when tried download his dsl, i cant found like you
origin % grep -l Method.*_OFF *.dsl
zsh: no matches found: Method.*_OFF
No ACPI files attached.
This is not origin. But disassembled. Attach fresh ACPI. Make sure you delete the old ones before grabbing new ACPI set.
WYLDE983
