Maple Ridge Firmware
utilman
MSI MEG Z590 ACE Gold Edition
Intel i9 11900K
ASRock Radeon RX 6700XT Challenger Pro 12GB OC
10.13.x
  1. iMac Pro
Hello guys,
I made a mistake at flashing the Maple Ridge rev 1.0 Firmware, WINBOND Chip.
I wanted to ask if someone can give me a dump or someone knows where i can get the original Maple Ridge Firmware?
Dont find on the Internet!
Thanks!
Or can maybe someone give me a picture of the electronic board? I think i was remove unwanted an resistor around the chip. Thanks
Hello guys,
Thanks!
What Card? AIC or onboard?
GIGABYTE MAPLE RIDGE Revision 1.0 (The only Revision) Thanks
Unfortunately, GIGABYTE has no firmware on their page. Try contacting GIGABYTE support if you do not have any backup of the firmware. It's always advised to backup your original firmware before flashing.
Thank you.
I have made three backups and checked all the hashes, all seems to be finde. I was also able to flash with suceed. But the card is not working. So i think i was push away a resistor from the board but i am not sure until i have a photo of the frontside of the electronic panel to check.
Sounds good.
Yes, a clear picture is required for an inspection.
Sounds good. Yes, a clear picture is required for an inspection.
So do anyone have a picture so i can look how the original should look like? Thanks a lot
You can attach the picture to inspect.
sorry i dont have such a good camera and you even wouldn´t see without the original. sorry
jkzql77089
