OpenCore Intel UHD 630 Dual Screen
What's the reason to spoof Video Device ID?
Yes, firstly I forget about that, but later I select one options and try but again some result, problem not solved,
Can you advice for settings please?
Attach your PR files.
Here are few issues,
- You should not use SSDT-EC and SSDT-USBX. Use SSDT-EC-USBX from the latest OC package.
- Framebuffer patching is incomplete. Each ports must be defined and patched to have a Hotplug function along with display.
Thanks for reply,
I'm fix the SSDT issue, I'm use SSDT-EC-USBX file now
I'm try different combination for framebuffer but I'm not have a succes yet
Did you any advice for framebuffer settings?
aaaaaw
