If your BIOS settings is changing, replace the CMOS.
Sorry I was not clear. When I boot to windows I need rebar but hackintosh won’t boot with it. So every time I switch to windows to play games I need to change bios. Is there a setting to make hackintosh boot with rebar on
What error do you get when booting?
It’s stuck there with rebar on
AMD 6900xt is working great in Big Sur however anytime I try to do HEVC transcoding in compressor or sending iMessage video the system would stall 50% of the time. On Monterey beta 5 it works 100% of the time. However, if I use HDMI to my TV + display port then on wake from sleep it would have a black screen until I remove HDMI and replugin display port. I have tried using this with and without Whatevergreen and both have the same issue. Any suggestions?
No PR files attached. Likely due to incorrect configuration.
See attached for EFI/OC folder. I only stripped out serial number. This is the version with Whatevergreen active.
Not as per the guide. Looks like you're using someone else's configuration.
Similar threads
xxxxxxxxxx
