HS80211Family.kext Is Not Compatible With macOS 12 Monterey.
ThiagoTx
Dell Inspiron 5458
Intel i5500U
Intel HD Graphics 5500
When I start my computer with this specific Kext on macOS Monterey the system gives a kernel error and does not start, for the system to start correctly I had to remove this kext for the system to start, everything works but without wi-fi on macOS Monterey.
What WiFi model?
Reactions: ThiagoTx
Technically, it should work. We're still testing it. Check the WiFi patch from here
Okay I Will Test! ;)
Unfortunately It Didn't Work, What I Do?
alexito
