Titan Ridge w/ no THB_C Header (PR zip included)
Thank you so much. Yeah I'm using them separately, I havent been able to get either working. This is with the Titan Ridge 2.0. I cant believe its showing up as a RAID controller and still not available :/ thank you again!
Incomplete PR files attached. IOReg is missing.
I ended up just swapping for the ProArt Z490 Creator, in the interest of time. Lost the white board but whatever. I was also trying to get two more TB3 ports added to the ProArt but that didn't work. even with flashed ROMs... I wouldnt say I gave up as much as I made a time centric decision lol
For now, we've been able to achieve 3xTitan Ridge, with total 6 ports of TB with most of the function. Is Z490 Creator working as indented?
Yessir! Perfectly! With Hotplug, cold boot, boot with no devices attached then plugging in. Only thing I haven't tested is sleep with drive mounted. You can add it to the success / tested list if you'd like. Using "G-Speed Shuttle RAID Thunderbolt 3". No drivers needed worked perfectly.
As far as the Titan Ridges...I'm utterly confused as I had tried damn near everything I saw online. I tried a flashed Titan Ridge & Alpine Ridge, I used the 3/5 pin short, and I used the DTPG.aml as well as modified and made the correct one using hackindrom. It would show up in system report every time, and even show the G-Speed, but not mount. I wonder if an audio interface or different device would have worked.
Perfect. Provide the screenshots+IOReg+TB Device models tested. It will be added under the list.
Well, in few case, that's normal. It also depends on the firmware you're using. It also depends on the installation and setup. We've tested a lot of motherboards from Z370 to X299X.
They're off with clients :/
I don't think I grabbed an IOReg on the ProArt Z490 Creator either, since it was working all fine.
any recommended ones? I tried Elias v23 and v50
Oh, damn. If you want, grab it and add it to the thread so users can have more information for test results.
DSM2 and NVM33.
Both ProArt Creator builds are with clients so I don't have access to them anymore :( But yeah, everything works super smooth with onboard compared to AIC.
DSM2 and NVM33.
Yeah interestingly I think it's problematic when the board has onboard TB3. but who knows, I'm definitely wrong there because I remember someone on tonymac got an AIC added WITH onboard TB3
Ah ok. Sounds good. Unfortunately, i would not be able to add this info to the thread without IOReg and screenshots.
We've never tested with case like yours. But it would be interesting to try it. Built-In TB3+AIC.
alexito
