SMBUS patch
Ok, thank you! Its good.
iStatsMenu have the same situation - no proc temp and fan speed.
In BIOS i have 2 option for temp control - intelligent and static.
When i chose Intelligent - CPU fan have different speed depend cpu temp? when i chose static - fan work on MAX speed all time.
In both cases - no cpu temp or fan speed in tools.
Provide BIOS settings. If a CPU FAN is installed, it should show. Make sure you have the same version of SMC kexts.
Also provide EFI, kextcache output.
Today i update Opencore to 0.6.6 and latest SMC kext 1.2 (same version sure) - nothing happened.
Bios show me cpu fan speed.
How i can do "kextcache output" ?
And can be problem with config ? Here i have only PlatformInfo-Generic section, in SMBIOS section - fields all blank.
kextcache -i/
kmutil done
View attachment 3021View attachment 3023
kextcache -i/
kmutil done
Looks fine. Remove "SSDT-SBUS-MCHC.aml" and then check.
Also, what's the system model?
sdfsad
