SMBUS patch
Hello!
Here is neccessary:
kextcache -i /
kmutil done
Mac Fan say in Russian: No fans find, try reset SMC
UP. I still need help.
Thank you
Hello!
Here is neccessary:
kextcache -i /
kmutil done
Thank you
The kexts are not being loaded in the correct order.
The correct order should be the following
VirtualSMC,
SMCSuperIO.kext
SMCProcessor.kext
To check whether SMBUS is loading or not, use the following command in Terminal.
kextstat | grep -E "AppleSMBusController|AppleSMBusPCI"
Thank you!
But change kext's order not work for me.
I try with SSDT-SBUS-MCHC.aml and remove it from config - result the same.
Executing: /usr/bin/kmutil showloaded
No variant specified, falling back to release
118 0 0xffffff7fa068d000 0x1000 0x1000 com.apple.driver.AppleSMBusPCI (1.0.14d1) 08A4B6D9-54C6-3632-B72C-69FA0625A0AB <14 6 5 3>
153 1 0xffffff7fa0682000 0x7000 0x7000 com.apple.driver.AppleSMBusController (1.0.18d1) D69C0758-0371-369E-88ED-E11402B91008 <152 14 13 6 5 3>
Thank you!
I add SMCProcessor and SMCSuperIO but can see only Core temp, still no fans.
I try without/with path but in both cases no fan.
May be i do something wrong ?
In Hackintool i see /PCI0@0/SBUS@1F,4 - it mean i must do PCI0.SBUS
in sample file i see:
External (_SB_.PCI0, DeviceObj)
External (_SB_.PCI0.SBUS, DeviceObj)
Scope (_SB.PCI0)
Device (_SB.PCI0.SBUS.BUS0)
May be this 2 bold must be equal ?
Like
Device (_SB.PCI0.SBUS)
or
External (_SB_.PCI0.SBUS.BUS0, DeviceObj)
May be i must do something here ?
Thank you!
This means the SMBUS drivers are loading.
im confused
The address doesn't needs to be changed as the device address is same as yours.
I tested it on a spare PC and it works at intended. Although, it has a issue with Custom controls. However, the temps and RPM are being shown.
You can use iStatsMenu to verify the temps and FAN RPM.
Ok, thank you! Its good.
iStatsMenu have the same situation - no proc temp and fan speed.
In BIOS i have 2 option for temp control - intelligent and static.
When i chose Intelligent - CPU fan have different speed depend cpu temp? when i chose static - fan work on MAX speed all time.
In both cases - no cpu temp or fan speed in tools.
sdfsad
