SMBUS patch
Dmitry 42
B360
i5-8400T
UHD 630
10.13.x
Hello!
When i use "fan control" - they say me : nothing finded, try reset smc.
So i think i must patch my SMBUS.
I read HOW TO: https://dortania.github.io/Getting-Started-With-ACPI/Universal/smbus.html and do this path from sample SSDT-SBUS-MCHC as described in link.
I chek kextstat and see loaded kext. But i still can't use fan control with the same error: nothing finded, try reset smc.
So what i do wrong? May be it must be not sample dsl file ? May be i must decompile original dsdt from my PC?
Or may be in "mac-mini" have not fan's and OS can control its ? My hack config is "macmini"
But when i open Intel Management Engine i can see Core speed and temp (!) without any dsdt path's.
Hello!
For that you'll need to use sensors kexts. Some of them are bundled with VirtualSMC package.
You can add the sensors kexts and check with iStat.
Thank you!
I add SMCProcessor and SMCSuperIO but can see only Core temp, still no fans.
I try without/with path but in both cases no fan.
May be i do something wrong ?
In Hackintool i see /PCI0@0/SBUS@1F,4 - it mean i must do PCI0.SBUS
in sample file i see:
External (_SB_.PCI0, DeviceObj)
External (_SB_.PCI0.SBUS, DeviceObj)
Scope (_SB.PCI0)
Device (_SB.PCI0.SBUS.BUS0)
May be this 2 bold must be equal ?
Like
Device (_SB.PCI0.SBUS)
or
External (_SB_.PCI0.SBUS.BUS0, DeviceObj)
So i test:
and
and
and no success.
Thank you!
Scope (_SB.PCI0)
Like
or
So i test:
and
and
and no success.
What FAN control app are you using?
Macs Fan Control 1.5.8.1 Free
I test it on my Macbook Pro with Big Sur - its work.
But not work on hack mac mini. May be original macmini have not fan ?
It works as per the SMBIOS info. That's what defines an Apple hardware.
Test it with a different SMBIOS like iMacPro 1,1 along with all the SMC sensors.
Also, note that, as per the developers, it doesn't supports Hacks officially.
I try 1.1 - system cant boot after OpenCore.
And i try 19.2 - boot, but still no fan ... so may be this problem not from platform id.
No PR files attached.
sorry, what is PR files ?
mulineee21
