Well, that's already explained in the guide.
DSDT is not patched. No HDAS to HDEF rename added. No Layout ID injected.
Probably, I2C Trackpad. Check Alexandred's VoodooI2C work.
Probably Atheros Killer or Intel which is unsupported and must be replaced with a compatible card.
DSDT must be patched.
Finger print is unsupported and will NOT work.
Framebuffer patching is required.
NVRAM issue.
The configuration is not as per the guide. Start here:
Ok, I start pathing DSDT. first I did these common patches :
  • Rename GFX0 to IGPU
  • Fix _WAK Arg0 v2
  • Fix Mutex with non-zero SyncLevel
  • HPET Fix
  • IRQ Fix
  • OS Check Fix windows 10
  • RTC Fix
  • SMBUS Fix
compile with no error, then I placed the patched DSDT file in EFI/Clover/ACPI/patched Folder. Restart the system and it loaded with no problem.
then I start from origin DSDT.dsl again do the common patches I mentioned and Do as this Guide you told said. use [bat] Asus g75vw patch in MaciASL, save the DSDT. download ACPIBatteryManager and copy ACPIBatteryManager.kext in library/extensions folder. then rebuild the cache sudo kextcache -i /
when I restart system this time it stuck in loading VoodooPS2Mouse...
tried more than one time but couldn't pass it and get battery work.
:rolleyes: its wired that first time that I patched my old DSDT file with [bat] Asus g75vw patch, it actually worked perfectly, but when I go to for A Beginner's Guide: How to Patch AppleHDA for Laptops I get this error and when I step back I start from beginning DSDT patch, couldn't get battery work again....
⬛ EFIFoldertheme deleted
SOLVED : problem comes from my common patches, when I patch DSDT just for battery I get battery WORK.
That patch is not intended for your system. Patch the .dsl again and use "[bat] ASUS N55SL/VivoBook" patch to enable battery meter.
Even if it worked, it's not intended for your Laptop.
A Beginner's Guide: How to Patch AppleHDA for Laptops I get this error and when I step back couldn't get battery work again....
Off-topic. Create a separate thread instead.
Note: For separate issues, create separate thread.
Reactions: promisedSavior
Hello. I have a elitebook 840 g2 i5
I’ve been using as main device fore some time now with clover and with hot patch from mr rehabman. I want to switch to open core . I’ve read about patching DSDT.aml, tried decompile using different iasl version from rehabman.
Every time I get this error in 10 lines
18992, 6126, syntax error, unexpected PARSEOP_INTEGER
original *.aml from Clover F4
I want to use my DSDT.aml in EFI/OC/... instead of the prebuilt ones from Open Core site for using with Big Sur
thank u for pointing me what to do
You must attach your original files.
Please escuse my ignorance
Files are still disassembled.
However, the DSDT doesn't have any single error when disassembling. Everything is as per the guide. Check your work and provide more information on your disassembly.
i did not used the external method definitions. my fault.
ok. now i have my DSDT.dsl. if i click compile i get only warnings optimisations, not errors.
next what to do save it as DSDT.aml without aplying any patches and put it into EFI/OC... ?
Warnings are normal.
If you don't apply the patches, it has no meaning.
fierofree
