On a Hack, this is different. If you're using OC, you can use NVRAM section and use "csr-active-config" property.
For Clover, you can use the guide below
done csrutil disable from the recovery mode,
capturing the video now with the downloaded patch.
The video quality is too bad.
Is this install vanilla?
Provide kextcache output.
I cant get kextcache from the recovery anymore, the crash clamped down even the recovery mode, even though I can boot to recovery mode, theres nothing I could do.
I will report back results until i get this done working.
To get kextcahe output, simply type the following in the Terminal and export it as a text from the Terminal.
sudo kextcache -i/
sudo kextcache -i/
now its vanilla(untouch) direct ESD, and I checked the /Library
Nothing in there. thats one of the error the script is spitting out.
I didn't get the chance to kextcache as the terminal has been clamped?, can't do any activity.
I think im starting to get the feeling where I am getting lost,
compared the mojave /Library with catalina,
Mojave have all of them, where in Catalina the /Library folder is empty.
Update:
Thru terminal, /Library/Preferences have all the com.apple.security files except com.apple.security.libraryvalidation.plist
Im sorry:
I was looking at the wrong volume.
Catalina /Library is empty on both finder and terminal
I already did a find / -iname "*validation*plist" search but to no result. Surprised to do this on the mojave volume, the search returned empty. Directly looking to /Library/Preferences I see no com.apple.security.libraryvalidation.plist at all.
- I guess this is one way of adding to the patch for safe fail safe, verify existence of the file/directory or no patch at all.
Update:
Im sorry:
Attach kextcache output.
Update:
Update:
Tried again, patch/Installer get past the library validation error, but failed with the OpenGL Framework same from the previous image/Video.
Got the copy of the com.apple.security.libraryvalidation plist.
and placed it under /Library/Preferences
SIP is fully disabled before I tried again.
So, where can I find these files/folders from the error.
Obviously they are not in my system,
Update: That's odd.
Checked the extracted patched file and see the files inside.
But I checked these folders inside catalina and mojave only the SkyLightframework folder is what I see.
I know for sure they are hidden, but if the patch can get to them, patch should have worked already.
I open the patch/post script found the copy part is missing a folder location that is why. Im gonna try again.
Dzikon
