BIOS/UEFI Settings for macOS (Intel/AMD)
Most motherboards will work with only a few changes from Optimized Defaults. However, for some systems, you must change the settings for booting macOS and optimal performance.Before you start making changes to your BIOS, ensure you're running the latest available BIOS/UEFI on your target system.
Here are some recommended Settings for your BIOS/UEFI. The settings are valid for Intel and AMD, including Laptops. To access your BIOS/UEFI, press and hold the Delete key on your Keyboard. The BIOS key may be different in your case. Refer to your Motherboard Guide/Manual for more information.
| Settings | Value | Notes |
X.M.P |
Windows 8/10 Features | Other OS | If you do not have the Other OS option, set it to Windows 8/10 Features instead. |
Network Stack | Disabled | |
Secure Boot | Disabled | |
Intel Platform Trust Technology (PTT) | Disabled | |
| EHCI Hand-Off | Enabled | |
XHCI Hand-Off | Enabled | |
SATA Mode |
| If your system does not have the AHCI option, set it to Intel RST Premium Intel Optane is not supported and will not work. |
VT-d | Disabled | Normally disabled. But if you have certain hardware (such as AQuantia/I225-V) or if you have to use Thunderbolt. When enabled, you must fix the DMAR Table. |
| Initial Display Output |
Internal Graphics |
| Auto
Intel Virtualization Technology | Enabled | |
Serial Port | Disabled | |
Parallel Port | Disabled | |
Fast Boot | Disabled | |
| Boot Mode |
| If you're having a UEFI based system, set this option to "UEFI" If you're having a Legacy based system, set this option to "Legacy." |
| Legacy Option ROMs |
| If you're having a UEFI based system, set this option to "Disabled." If you're having a Legacy based system, set this option to "Enabled" |
| Compatibility Support Module (CSM) | Disabled | If you're having a Legacy based system, set this option to "Enabled" |
| Integrated NIC | Enabled | |
| SMART Reporting | Enabled | |
| Thunderbolt Support | Enabled | |
| HyperThread | Enabled | |
| Intel Turbo Boost | Enabled | |
| CFG Lock | Disabled | If the target system does not have this setting, you must configure the AppleXcpmCfgLock and |
| Above 4G Decoding | Enabled | |
| Above 4GB MMIO BIOS Assignment | Enabled | Some systems with Raptor Lake CPU may require this setting to be enabled or the system will not boot at all. |
Notes:
- If you're using IGPU as a Graphics Device, set Internal Graphics to Enabled and DVMT to 64MB.
- If you're using only Discrete Graphics, set Internal Graphics to Disabled.
- To disable Secure Boot, you might need to clear the Security keys, (Platform Keys (PK)) on some systems. These keys are located under "Key Management."
- For some laptops, you need to set the Administrator password when disabling Secure Boot otherwise you might get a "Secure Boot Fail" message when booting using a USB installer.
- For some Dell Laptops, if your Laptop restarts while plugging/unplugging the AC Adapter, try changing the Legacy Option ROMs setting. If it's enabled, try to disable it. If it's disabled, try to enable it.
- If your System doesn't have any of the above mentioned settings, you can skip those settings.
GUIDE - How to Enable ThunderBolt on macOS
How to Enable ThunderBolt 2, Thunderbolt 3 and Thunderbolt 4 on maOS [Clover/OpenCore] An EliteMacx86 Exclusive Guide - This guide covers implementation of Thunderbolt 2, Thunderbolt 3 and Thunderbolt 4 on macOS using Clover and OpenCore. Overview This guide covers the implementation of...
www.elitemacx86.com
