BIOS/UEFI Settings for macOS (Intel/AMD)
Most motherboards will work with only a few changes from Optimized Defaults. However, for some systems, you must change the settings for booting macOS and optimal performance.
Before you start making changes to your BIOS, ensure you're running the latest available BIOS/UEFI on your target system.
Here are some recommended Settings for your BIOS/UEFI. The settings are valid for Intel and AMD, including Laptops. To access your BIOS/UEFI, press and hold the Delete key on your Keyboard. The BIOS key may be different in your case. Refer to your Motherboard Guide/Manual for more information.
SettingsValueNotes
X.M.P​
  • Profile 1
  • Enabled
  • On some motherboards, you may not find this option. In such a case, set this option as Enabled.
  • On ASUS Motherboards, set Ai Overclock Tuner to "XMP."
  • On ASRock Motherboards, set it to Auto.
Windows 8/10 Features​
Other OS​
If you do not have the Other OS option, set it to Windows 8/10 Features instead.
Network Stack​
Disabled​
Secure Boot​
Disabled​
Intel Platform Trust Technology (PTT)​
Disabled​
EHCI Hand-OffEnabled
XHCI Hand-Off​
Enabled​
SATA Mode​
  • AHCI​
  • Intel RST Premium​
  • Intel Optane​
If your system does not have the AHCI option, set it to Intel RST Premium
Intel Optane is not supported and will not work.
VT-d​
Disabled​
Normally disabled. But if you have certain hardware (such as AQuantia/I225-V) or if you have to use Thunderbolt.
When enabled, you must fix the DMAR Table.
Initial Display Output
  • PCIe 1 Slot
  • PEG/PCIe
  • IGPU
  • This setting is usually found on Desktops.
PCIe 1 Slot
  • If you're using a dedicated GPU, set this option to "PCIe 1 Slot."
PEG/PCIe
  • Some BIOS/UEFI may not have a PCIe 1 Slot setting. PEG/PCIe is an alternative to it.
IGPU
  • If you're using IGPU, set it to IGPU.
Internal Graphics​
  • Auto​
  • Enabled​
  • Disabled​
Auto
  • If you're using IGPU+DGPU, set this option to Auto. IGPU will run in headless mode.
Enabled
  • If you're using IGPU, set this option to Enabled.
IGPU
  • If you're using DGPU, it's recommended to set this option to Disabled.
  • Disable IGPU for Rocket Lake and above CPUs. Only enable if you have to utilize IGPU on Windows for QuickSync feature.
Intel Virtualization Technology​
Enabled​
Serial Port​
Disabled​
Parallel Port​
Disabled​
Fast Boot​
Disabled​
Boot Mode
  • UEFI
  • Legacy
If you're having a UEFI based system, set this option to "UEFI"
If you're having a Legacy based system, set this option to "Legacy."
Legacy Option ROMs
  • Enabled
  • Disabled
If you're having a UEFI based system, set this option to "Disabled."
If you're having a Legacy based system, set this option to "Enabled"
Compatibility Support Module (CSM)DisabledIf you're having a Legacy based system, set this option to "Enabled"
Integrated NICEnabled
SMART ReportingEnabled
Thunderbolt SupportEnabled
HyperThreadEnabled
Intel Turbo BoostEnabled
CFG LockDisabledIf the target system does not have this setting, you must configure the AppleXcpmCfgLock and
Above 4G DecodingEnabled
Above 4GB MMIO BIOS AssignmentEnabledSome systems with Raptor Lake CPU may require this setting to be enabled or the system will not boot at all.
Notes:
  • If you're using IGPU as a Graphics Device, set Internal Graphics to Enabled and DVMT to 64MB.
  • If you're using only Discrete Graphics, set Internal Graphics to Disabled.
  • To disable Secure Boot, you might need to clear the Security keys, (Platform Keys (PK)) on some systems. These keys are located under "Key Management."
  • For some laptops, you need to set the Administrator password when disabling Secure Boot otherwise you might get a "Secure Boot Fail" message when booting using a USB installer.
  • For some Dell Laptops, if your Laptop restarts while plugging/unplugging the AC Adapter, try changing the Legacy Option ROMs setting. If it's enabled, try to disable it. If it's disabled, try to enable it.
  • If your System doesn't have any of the above mentioned settings, you can skip those settings.
For more information on Thunderbolt settings, refer to the guide linked below.
If i have a mobo AMI UEFI, should i use Legacy or UEFI 64 to install Mojave with clover?
You should use UEFI boot mode. As always, UEFI is more better.
I am running into an error here, where it hangs on "S7.126041 XHC". This is an MSi X299 toMohawk, and Intel i9-10920. I have set my bios as follows:
SettingsValue
X.M.PProfile 1
Windows 8/10 FeaturesN/A
Network StackDisabled
Secure BootDisabled
Intel Platform Trust Technology (PTT)Disabled
EHCI Hand-OffN/A
XHCI Hand-OffEnabled
SATA ModeAHCI
VT-dDisabled
Internal GraphicsN/A on X299
Intel Virtualization TechnologyEnabled
Serial PortN/A
Parallel PortN/A
Fast BootDisabled
Boot ModeUEFI
Legacy Option ROMsDisabled
Integrated NICN/A
SMART ReportingN/A
HyperThreadEnabled
Notes:
Reactions: Max.1974
SettingsValue
X.M.PProfile 1
Secure BootDisabled
EHCI Hand-OffN/A
SATA ModeAHCI
VT-dDisabled
Serial PortN/A
Parallel PortN/A
Fast BootDisabled
Boot ModeUEFI
Integrated NICN/A
SMART ReportingN/A
HyperThreadEnabled
Notes:
The problem is likely due to incorrect configuration. The BIOS settings seems fine.
Thanks!!
  • Love
adamnor206
