[SOLVED] macOS Catalina and Intel HD 4400
Attached new PR files
Done. What's next?
There is a problem. I don't know what I need to do with that tutorial. Remove unnecessary kexts and drivers, or what?
After that, you need to follow the guide and prepare a correct configuration as per the guide.
Done, uploaded new PR files.
EDIT: Reuploaded PR files, because I forgot to compress the CLOVER folder
The drivers directory is not as per the guide.
The config.plist is not intended for your hardware. Use "config_HD4600_4400_4200.plist".
Attach new PR files.
Done.
PR files attached.
Done.
PR files attached.
Still, the drivers directory is not as per the guide.
The copy of IOReg is old.
Attach a fresh PR files with above issues fixed.
Nightic
