Thx bro Awesome work , The Fix Work 110%
Hi,Distortion only occurs when the system is turned on or when waking from hibernation, and it resolves only after logging into the system. This is very annoying, especially when turning on the system and when the Apple logo appears from the headphones you can hear crackling noises.
Dell e5440 CPU:Intel Core i5-4300u GPU: HD4400 Ram: 2x4gb DDR3 Audio: Realtek alc292 Wifi: Atheros ar928x Mojave
PS: I just deleted AppleALC and leave only VoodooHDA + CodecCommander
Made an account just to say thank you!!!!
Is there any way i can make the script run silently? Or atleast close itself after finishing
It's recommended to use AppleALC method for best results. VoodooHDA is already a crap. For now, this is the only solution.
Yes, you can just add the script to the login so that it can be executed silently.
Yah now It does work Properly, Thank you So Much
ilikeeatingpeeandpoo
