When I following guide step by step I'm getting "Could not locate CodecCommander kext, ensure it is loaded." May be problem in opencore bootloader?
CodecCommander must be installed and added to the OC configuration. I suggest you to use Clover so it can be easy for you.
I retried guide step-by-step with clover installation. If I have cc kext only, I have error "Could not locate CodecCommander kext, ensure it is loaded." When im adding VoodooHDA (like one man on first page of thread) this error dissapears, but fix not works. My EFI/CLOVER: https://1drv.ms/u/s!As7QXHuuZX69hP0zabflDNjrNXT8hg?e=RIRdqP (AppleALC deleted from this folder)(can't upload on this site, too big)
i still have this problem. Alc 668(3661)
The ACPI is not patched correctly. The config.plist has Layout ID=3 and the config.plist has Layout ID=1.
FakePCIID.kext is not required. Remove it.
Thanks. I have fixed ALC255 😘 Catalina 10.15.1
J.An
