I see...Then do I need to reinstall again if I use my onboard Intel GPU?
No need to reinstall. Enable IGPU from the BIOS and plug the cable to IGPU. Boot and check
Now I faced with gfx firmware retry errors....:oops:
OK...Thanks..Will try again..
Hi, managed to have some time to try again....the errors are gone....but not I'm stuck in a white screen with only the mouse cursor for the past 2 hours....normal?
Use fake ig-platform-id to boot. Such as 0x12345678.
I got it working using Clover5119..thanks
nicolacibin08
