The five files for the clover,l boot, starting with FakeSMC.kext to WhatevrGreen.kext
The links aren't working?
Make sure you read the notes carefully.
I can find the link and when im on it I press the green clone or download button, that just gives me some file with a load of other files and kexts, but I couldn't find the neccesary kexts to boot macos.
The kexts are found in the release folder.
I could not find the release folder, is it in the download or somewhere else?
It's already mentioned in the guide. I've attached screenshot as a reference.
I downloaded them, clicked the link and clicked the download button, got a folder with a bunch of files but no kexts or release
That's absolutely wrong. As mentioned in the note, the downloads are available in the Readme. For e.g. if i need to download the FakeSMC, visit the above link, scroll down and you'll see a link. See the screenshot for the reference.
Hi, I had successfully installed Mac OS in my system. During first boot, you mentioned it may be slower due to building cache but I'm at the screen for the past one hour and no activity. Is this normal?
The logs indicate Graphics issue.
Attach your PR files. Your profile indicates that you're using NVIDIA RTX 2070 GPU which is unfortunately, not supported.
I see...Then do I need to reinstall again if I use my onboard Intel GPU?
nicolacibin08
