Audio is another part. The original thread was about patching errors which has been fixed and the thread must be closed for other issue, a separate thread must be opened. :)
ok, thanks but patching is not completed
I must do Layout ID patch after enabling audio, is this correct?
Note that this thread was specifically opened for the DSDT errors you had. ;)
While enabling audio, suppose you use layout ID=3, the same must be patched for your DSDT. Check the laptop guides for more information.
ok I created another thread for audio please answer it
but please let this be opened if any other DSDT errors occur later
here's its link
have you any fix?
Of course.
here's its link
have you any fix?
I have not got time to check the thread yet.
I reached to this step :
Full patched DSDT + SSDTs:
- Patched DSDT.aml in ACPI/patched
- Full set of patched OEM SSDTs in ACPI/patched (SSDTs names must be same as in ACPI/origin)
- Add-on SSDTs also placed in ACPI/patched
- SortedOrder required to set SSDT load order(SSDTs order must be same as in ACPI/origin)
- DropOem=True
in the SortedOrder stage what should I do?
also, what are Add-on SSDTs?
You need to add all the DSDT and SSDTs to the sorted order.
Add-on SSDTs are the separate SSDTs which are not found in your system. One of the example is SSDT-PNLF.
how should I add them? just their names or with extension or other things? in what order?
Check the following guide for a better understanding.
daemon6109
